i have a 97 with a hypermax h2e turbo banks inercooler edge evo and edge ez my boost gauge says 15 psi i no that isnt right does anyone no about how much boost im pushing i think theres a vaccume leak in the boost line
Are you still running stock injectors? If so you may not have enough fuel to spool that turbo good.
yea im runnin stock injectors thats wat i was thinkin cause even with the 2 chips i still dont have any smoke im about to put the aroura 5000 guts in the turbo wat size injectors should i go with and i need the hpops and fuel system anyone no of a good brand to use
Get some Hybrids. You don't need big oil and they should work great with that turbo. It's got nothing to do with the turbo it's you don't have enough fuel. Stock '97 injectors only flow 90cc unless it's a cali model then they flow 135cc. You can get some great injectors from DDP. (360) 794-7974.
