vin:1FTSW31P84ED14072
thanks scott
OASIS RESULT:
1FTSW31P84ED14072
12/04/2006
08:23:22
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/25/2004 BUILD DATE
04/08/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
06/12/2006
DEALER: Pride Ford of North Attleboro,
WARRANTY CLAIM NUMBER: 016228 ODOMETER: 041431M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D 42 DOES NOT OPERATE PROPERLY
000 12650D30
RECENTLY HERE FOR A SERVICE ENGINE LIGHT CONCERN REPLACED THE EGR SENSOR AND CLEANED INTAKE
06/02/2006
WARRANTY CLAIM NUMBER: 015988 ODOMETER: 041242M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 14A411A WIRE ASY MAIN JUMPER 001 12650D 42 DOES NOT OPERATE PROPERLY
000 12650D45
000 12650D80
000 12650D81
000 12650D84
000 12650D9
000 14200A
DIVING FINE AT THIS TIME PERFORM ON-DEMAND SELFTEST,RETRIEVE DTC'S P0404 AND P1335(EGR RELATED)CHECK TO SEE IF A LATER PCM CALIBRATION IS AVAILABLE-NO.C ALIBRATION# 4U7A-12A650-BGH.PERFORMED PIDS MONITORING EGR POSITION,VOLTAGE A ND COMMANDING POSITION. PERFORMED SSM 18846R&R EGR CONNECTOR
03/13/2006
WARRANTY CLAIM NUMBER: 420056 ODOMETER: 035798M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 6089A 42 DOES NOT OPERATE PROPERLY
5C3Z 6F089A ACTUATOR ASSY 001 12650D
000 12650D9
000 12650D81
000 12650D45
CHECK FOR ENGINE LIGHT ON LOOK AT PIDS WHILE STARTING ICP MAP BARO SYNC FICM EBP FUEL PW CHECK FUEL FOR ANY CONMNATES CHECK AIR FILTER AND FUEL FILTER S TART UP AND PIDS READING AND LET RUN GET WARM
03/13/2006
LABOR OP
CONDITION CODE
CONDITION DESC
7A030 INLET/OUTLET COOLER 000 MT7A030 D8 FAILED GASKET/SEAL
PM 17A MOTORCRAFT BATTERY 001
PM 18A 001
CHECK FOR TWO DRIPS ON TRANNY CROSS MEMBER CHECK PUT DIE IN TRANNY AND CHECK WITH LIGHT FOUND TRANNY FITTINGS LEAKING REMOVE AND FLUSH LINES AND CLEAN A ND PUT TEFLON TAPE AND CHECK FOR LEAKS NONE
02/15/2006
WARRANTY CLAIM NUMBER: 417470 ODOMETER: 035201M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 12650D 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 12650D30
000 9424A
CHECK FOR NO PEDAL INPUT LOT SMOKE ROAD TEST AND TRY TO VERIFY CHECK FUEL FO R CONNAMINATS AND CHECK AIR FILTER CHECK FUEL TO HEADS AND CHECK FUEL ARATIO N PASS AND OIL LEVEL AND OIL ARATION PASS CHE
01/30/2006
WARRANTY CLAIM NUMBER: 415831 ODOMETER: 034245M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K775BA COOLER ASSY 001 6020A D8 FAILED GASKET/SEAL
6C3Z 6C640AA CONNECTION A/C DUCT 001 6775A
3C3Z 9F836BA PEDAL & SENSOR ASY 001 6646AH
3C3Z 6020CA GASKET CYL TIMING GE 001 9758A
CHECK FOR OIL LEAK IN FRONT OF TRUCK PUT DIE CHECK WITH LIGHT AND NEED TO TA KE APART TO VERIFY LEAK REMOVE TUBES AND UPPER INTAKE AND REMOVE TURBO AND P EDASTAL REMOVE FAN SHROUD FA
END OF OASIS REPORT FOR 1FTSW31P84ED14072
