2nd Gen Guru
Hey Gang...
Once again I'm looking for some help with my truck. Lately my rear brakes have been binding up and dragging. I clean the rails the shoes ride on and the shoes themselves. Externally mostly lost of mud and dirt. Well I popped out a piston to check the bores for problems and found that sand and very small stones under the weather boots. (I can't figure out how they got there...)
But found that the sand and debris has worked its way under the O-rings in the calipers. Now my problem is that everything is fine except the O-rings which has taken some damage. (Deformed, nicks, etc.)
Now I went to the local NAPA store and they don't list any rebuild kits for the 2002 Dodge Cummins at all... Only $120 buck per caliper (new assemblies!) I would need 2 of them...
But the very same day I was ordering rebuild kits for a 1961 GMC 4000 Firetruck and they had 2 on stock for a total of $45 bucks...
Why is it that you can get parts for a 47 year old firetruck but can't buy a simple rebuild kit for a 6 year old truck???
Well enough ranting... I need to know if there is a alternate part number or something... I just don't see $120 per axle... It only a cheap $5 to $10 buck seal...
Take notice to the chunk missing on the right...
2nd Gen Guru
Well it seems I solved my own problems again...
Ahhh!!! But I just got off the phone with my local parts guy in Council, ID he got in contact with Hometown Motors (Dodge Dealer) in Weiser, ID and found seals and 1 piston (Brand New!)
$22.20 Piston
$1.45 Seals
That is much cheaper than $120 bucks per caliper... :woot:
