well after doing a complete brake job on my 89? 90 Dodge dually I finally found the problem--BAD Vacume Pump--& heres my problem--MOPAR has three Power assist brake systems--Mine--Vacume--Air--where I*D have to install an Air Compressor--& Hydralic--I assume?? part of the Power steering Pump?--now--I have a Hard solid brake peddel--like driving a Model "A"--but it just slows down--Not acceptable--has any one? changed over to another brake system?--what? does it entail?--I assume?? the hydralic system would be?--changing the power steering pump!! & an Add on to the Master Cylinder?--some how?--I got it State Inspected--but--if? I ever had a Panic Stop!--I*M in BIG Trouble!--& I won*t drive it --w/ the Brakes in that manner--any HELP Appricated!!--Ole JIM--
The light stuff is vacuum boost, some of the heaver light stuff is hydroboost. In the middle of the med duty there have been some air over hydraulic, now hard to get repaired. At the top of the MD there is air brakes. No parts to fit air brakes to light stuff.
I hear rumors of an air brake compressor for b Cummins and have seen one - without the PS pump, don't know if both will fit in the space.
keydl
