Do you have to break in a vp44? I just installed my new pump and new injectors. I have not hooked up my drag comp and was wanting to know if I should wait or if it even matters.
I can't see why it would matter. I don't know for sure.
Sean, Bouncer or MoparMan might be able to give ya a straight answer.
The ones I've put in I just sent the person on there way. However sometimes you here about ones that are DOA.
2nd Gen Guru
I would consider a good lubricant additive for the life of the pump. But that only a suggestion.
http://mopar.mopar1973man.com/2002 Dodge/Tips & Tricks/2 cycle oil/2_cycle_oil.htm
As for any kind of tight machined parts I would run it a little while before putting up full load of the Drag Comp. You can hook up your Drag Comp but keep it down low for a few miles till everything seats in properly...
Just a wize choice...
