1996 pete 379 c15 cat broke down today when i was getting started this morning checked for fuel restrictions ,fuses,even in the dash,finally had to either start,started but no trottle response im thinking ECM can anybody tell me what else i can check
You want to start with the basics, Clean all the battery connections, take them apart and be sure they are clean, clean the ground connections, especially to the block, head and cab. Check the fuel, for sucking air, and for air in the return fuel.
Do you have any codes?
broke down
i did disconnect some of the batteries thinking this would reset something but ididnt take all off maybe makes since because been having starting issues lately,?would that have something to do with ecmwill clean all in the mrng and ,thank you.
Yea man check your electrical connection. Assuming they are good. Assuming fuses and wires for throttle Are good then could be ECM.
