Smokin
I'm buying this week trying to see if there has been any head gasket or egr problems. Thanks very much for your time.
1fmsu45p95ea12986
Standard Claims List For Model Year 2005
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 10 2E06 030008 4C3Z 9E527 AA D02 42 16411
AWS Claim Key: 2452884 Trx Code: S07 Labor Hrs: 6
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2005 Doc #:04515851
Cust Comments: C S ENG DIED IN MOTION STARTED TO LOOSE POWER DIED
Tech Comments: PERFORMED DIESEL ENGINE HARD START DIAGNOSTICS,REMOVED RIGHT SIDE AND LEFT SIDE VALVE COVERS AND REPLACED NO2 AND NO 5 INJECTORS
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 10 2D03 030803 * 12226 * C19 V3 16489
AWS Claim Key: 2467436 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2005 Doc #:04555251
Cust Comments: AC VENT DONT BLOW
Tech Comments: VERIFY COMPLAINT DIAGNOSIS PRESSURE TEST SYSTEM FULLA C BLOWS THROUGH DEFROST ALL THE TIME AND WARM AIR. PERFORMED VACUUM LEAK TEST R R A C CONTROL PANEL TRACE AND REPAIR MAIN VACUUM FEED BLACK HOSE,BEHIND DASHPANEL KINK AND LEAKING.REROUTED HOSE ROAD TEST.FINAL PRESSURES 30.200 A C BLOWS 45 DEGREES THROUGH VENTS,
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 12 1H03 030008 5C3Z 9F452 AA D36 42 21820
AWS Claim Key: 3318810 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 04405 - * Name: COMMERCIAL MOTOR COMPANY Ph: 361-7585361 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2006 Doc #:040940A
Cust Comments: ENG MISSES AT HIWAY SPEEDS ON ACCELL MAKES BLACK SMOKE AT THAT TIME
Tech Comments: EEC TEST, DOEO PASS, CONT PO404, R T MORE THAN 10 MILES BEFORE DUPLICATED ABOUNT 2000 RPM 60 M PH MISS JERK AND BLK SMOKE HARD TO ACCELERATE SOME TIMES RUN BAD, PERFORM PPT W FOR EGR TEST PASS AT BY. FOLLOW PERFORMANCE SHEET DIAG STEPS , REPEAT TESTS TWO TIMES SYS OK, R T, MONITOR A ND RECORDER, MAKE TWO RECORDINGS PIDS OK, EGR COMMAND 80% EGR TP VOLT ONLY 1.8 ONLY AT THE SP
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 12 7H05 120403 5C7Z 19980 AB C05 42 22324
AWS Claim Key: 3704961 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2006 Doc #:04928251
Cust Comments: AC DISPLAY DOES NOT WORK AND THE AC DOES NOT COME ON
Tech Comments: VERIFY COMPLAINT DIAGNOSIS, PRESSURE TEST SYSTEM FULL. PRESSURES 120.50 COMPRESSOR NOT COMING ON AND AC CONTROL PANEL HAS NO DISPLAY. PERFORMED ELECTRICAL TEST AND REPLACED AC CONTROL PANEL DUE TO INTERNAL DAMAGE. FINAL PRESSURES. 30.200 AC BLOWS 45 DEGREES.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 12 * * * * * * * 22324
AWS Claim Key: 3704962 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2006 Doc #:04928253
Cust Comments: PROGRAM 59B01: QUALITY ASSURANCE TEST DRIVE
Tech Comments: PERFORM QUALITY ASSURANCE TEST DRIVE.
AWS Claim Key: 3645674 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2006 Doc #:04928252
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACMENT
Tech Comments: EXHAUST PRESSURE (EP) SENSOR REPLACEMENT, AND RECALIBRATE CONTROL MODULES PER RECALL.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 19 7D07 17XXXX F4CZ 13466 A L26 42 35500
AWS Claim Key: 5690407 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04574 - * Name: VON-WIL FORD, INC. Ph: 979-5324360 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2006 Doc #:03200301
Cust Comments: CUSTOMER STATES LEFT REAR BLINKER WILL NOT WORK
Tech Comments: REPLACE LEFT REAR TURN SIGNAL BULB
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 47 2H01 030008 5C3Z 6K854 BA E42 D8 37999
AWS Claim Key: 10682535 Trx Code: E72 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2008 Doc #:598345C
Cust Comments: CUSTOMER STATES THAT THERE IS A TICKING SOUND WHILE RUNNING CHECK AND ADVISE
Tech Comments: 38005 6K854 CONDITION CODE D8 VERIFIED EXHAUST LEAK AT REAR OF ENGINE. PINPOINTED LEAK TO Y PIPE ON DRIVERS SIDE. REMOVED TURBO AND REMOVED YPIPE. REPLACED YPIPE AND INSTALLED NEW GASKET EXHAST BOLTS AND NEW NUTS. INSTALLED REMOVED COMPONENTS AND VERIFIED LEAK IS NO LONGER PRESENT.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 47 2E03 030402 4C3Z 9E527 BRM D13 42 37999
AWS Claim Key: 10688106 Trx Code: S07 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2008 Doc #:598345A
Cust Comments: CUSTOMER STATES THAT VEHICLE RUNS ROUGH CHECK AND ADVISE
Tech Comments: 38005 9E527 CONDITION CODE 42 VERIFIED VEH IS HARD TO START ON COLD START. PERFORMED PRECHECKS AND FOUND ENGINE OIL AND FUEL OK. CHECKED FOR DTCS AND FOUND INJECTOR CONTRIBUTION BALANCE MISFIRE CODES FOR CYLINDERS 1 4 AND 5 0263, 0272, 0275. PERFORMED TSB 070504 AND PROGRAMED MODULES TO LATEST CALIBRATION. TESTED ON COLD START AND FOUND MISFIRE FROM CYLINDERS 1 4 5 6.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 47 1D01 030201 3C3Z 6700 BA L65 D8 37999
AWS Claim Key: 10688107 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2008 Doc #:598345B
Cust Comments: CUSTOMER STATES THAT THERE IS A OIL LEAK CHECK AND ADVISE
Tech Comments: 38005 VERIFIED OIL LEAK AT FRONT OF ENGINE. CLEANED AND RAN VEH WITH OIL DYE. PINPOINTED LEAK AT FROM CRANK SEAL. REPLACED CRANK SEAL AND VERIFIED OIL LEAK IS NO LONGER PRESENT.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 48 * * * * * * * 39701
AWS Claim Key: 10682536 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2008 Doc #:599024C
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 39715 INSTALL LABEL ON DEGASS BOTTLE PER RECALL 05B32.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 48 1A02 030102 4C3Z 6051 EB L87 42 39701
AWS Claim Key: 10688108 Trx Code: E72 Labor Hrs: 17.1
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2008 Doc #:599024A
Cust Comments: C S TRUCK LOSING COOLANT FROM DEGAS BOTTLE
Tech Comments: 39715 TSB 08 11 3, BP# 6051, CC 42 VERIFY COOLANT VENTING FROM DEGASS BOTTLE ON SHORT ROAD TEST. PERFORM DIAG AS PER TSB 08 11 3. PRESSURE TEST CAP PASSED.. HOLDS PRESSURE AND VENTS AT 16 PSI. VACUUM TEST EGR COOLER ON VEH. PASSED. HELD 15 VACUUM FOR 15 MINUTES. ROAD TEST CEH WITH PRESSUR TESTER INSTALLED AND IDS DATAMONITOR. ECT AND EOT TEMPS CHECK GOOD. PRESSURE CLIMBS DURRING WOT AND
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 50 1B03 030204 3C3Z 6A642 AA L87 42 47665
AWS Claim Key: 10823896 Trx Code: E72 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2009 Doc #:601946A
Cust Comments: CUST STATES ENGINE HAS COOLANT LEAK
Tech Comments: PERFORMED TSB 8 11 03 F
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 53 2H01 030407 5C3Z 9G489 AARM P59 69 59920
AWS Claim Key: 11030974 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2009 Doc #:607597A
Cust Comments: C S TRANS SERVICE LIGHT IS ON P09
Tech Comments: 59920 69.9G489 VERIFIED SES LIGHT IS ON. PERFORMED VISUAL INSPECTION, NO CONCERNS PRESENT. CHECKED FOR SUFFICIENT CLEAN FUEL, APPEARS GOOD. CHECKED ENGINE OIL LEVEL, OIL LEVEL WITHIN SPEC. PERFORMED KOEO TEST, PULLED CODE P0299. RETRIEVED CMDTC P0299. PERFORMED KOEO INJECTOR ELECTRICAL SELF TEST, TEST PASSED. PERFORMED POWER BALANCE TEST, TEST PASSED. PERFORMED INTAK RESTRICTION
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 53 5G04 040105 2C7Z 5484 AA N50 30 59920
AWS Claim Key: 11030975 Trx Code: 0701D Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2009 Doc #:607597C
Cust Comments: C S RATTLE IN FRONT END WHILE DRIVING N50
Tech Comments: 59920 30.STABILIZER BAR BUSHINGS VERIFIED RATTLE IN FRONT END. USED CHASSIS EARS AND FOUND THE NOISE COMING FROM THE STABILIZER BUSHINGS. BUSHINGS ARE EXCESSIVELY WORN. REPLACED THE BUSHINGS AND TEST DROVE. VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 53 7B02 140201 4C3Z 10V346 AARM D50 63 59920
AWS Claim Key: 11023520 Trx Code: 0701D Labor Hrs: 2.2
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2009 Doc #:607597B
Cust Comments: C S ALTERNATOR LIGHT IS ON D50
Tech Comments: 59920 63.ALTERNATOR VERIFIED BATTERY LIGHT IS ON. BATTERY TESTED BOTH BATTERIES AND TEST PASSED. TESTED ALTERNATOR AND ITS CIRCUITS, FOUND ALTERNATOR WEAK AND ONLY PRODUCING 12.6VOLTS. REMOVED THE SERPENTINE BELT AND REPLACED THE ALTERNATOR ASSEMBLY. RE TESTED AND FOUND ALTERNATOR NOW CHARGING AT 14VOLTS. VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 54 1H03 030008 5C3Z 9F452 AA D42 69 62155
AWS Claim Key: 11046171 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-JUN-2009 Doc #:608373A
Cust Comments: C S NO POWER AND BLACK SNMOKE FROM EXHAUST D42
Tech Comments: 62155 69.9F452.9E527 VERIFIED SES LIGHT IS ON. PERFORMED VISUAL INSPECTION, NO CONCERNS PRESENT. CHECKED FOR SUFFICIENT CLEAN FUEL, APPEARS GOOD. CHECKED ENGINE OIL LEVEL, OIL LEVEL WITHIN SPEC. PERFORMED KOEO TEST, PULLED CODE P0302 P0303 AND P0401. RETRIEVED CMDTC P0302 AND P0303. PERFORMED KOEO INJECTOR ELECTRICAL SELF TEST, TEST PASSED.PERFORMED POWER BALANCE TEST, TEST FAILED.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 54 1H06 031403 2L1Z 9F479 AA D42 55 63307
AWS Claim Key: 11067312 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2009 Doc #:609099A
Cust Comments: C S VEHICLE HAS NO POWER AND SMOKES A LOT
Tech Comments: 63307 CC 55 ... CP 9F479 ROAD TEST TRUCK, HAS ERRATIC TURBO OPERATION, AND BLOWS HEVY BLACK SMOKE AT TIMES UNDER HARD ACCELERATION. RUN PARTIAL PERFORMANCE DIAG SHEET, PRELIMINARY CHECKS ARE OK. RUN KOEO & KOER SELF TESTS, HAD DTCS P1408 P2262 MEMORY CODES. RAN AIR MANAGEMENT EGR TEST AND PASSED ALL TESTS, RAN TURBO BOOST TEST AND 2.15 PASSED. CHECKED FUEL PRESSURE
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 55 2D02 160101 7C3Z 9H465 A P82 28 65611
AWS Claim Key: 11152989 Trx Code: 0701D Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2009 Doc #:610576E
Cust Comments: CUST STATES 4X4 IS INOP
Tech Comments: 65611 28.9H465 VERIFIED 4X4 IS INOP. WENT TO PINPOINT TEST, CHECKED VACUUM SOLENOID FOR VACUUM APPLIED. FOUND VACUUM TO THE VACUUM SOLENOID BUT NOT COMING OUT OF THE OTHER SIDE WHEN COMMANDED. VERIFIED CORRECT POWER AND GROUND WHEN COMMANDED. OHMS TESTED THE 4X4 SOLENOID AND FOUND IT HAS AN OPEN CIRCUIT INTERNALLY. REPLACED THE SOLENOID AND RETESTED. VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 55 2A01 031202 6C3Z 6C640 AA L85 D8 65611
AWS Claim Key: 11152990 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2009 Doc #:610576F
Cust Comments: C S ENGINE OIL LEAK L85
Tech Comments: 65611 D8.6C640 VERIFIED ENGINE OIL LEAKS. PERFORMED OIL LEAK DYE TESTING AND FOUND LEAK COMING FROM THE COLD SIDE AIR INTAKE DUCT BETWEEN THE CAC AND THE INTAKE ELBOW. PULLED OASIS AND FOUND TSB 05 22 03. REPLACED THE PIPING AS PER THE TSB AND VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 55 5B03 050301 2C3Z 3010 AA H44 42 65611
AWS Claim Key: 11155026 Trx Code: 0701D Labor Hrs: 6.2
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2009 Doc #:610576A
Cust Comments: C S FRONT END WOBBLES AND JERKS OVER BUMPS H44
Tech Comments: 65611 61.3010 VERIFIED FRONT END SHAKES TOO MUCH OVER BUMPS. INSPECTED CHASSIS AND FOUND THE FRONT DIFF TO ROLL BAR BRACKET BRACKET IS BROKEN OFF DUE TO A DEFECTIVE WELD. REMOVED FRONT DIFFERENTIAL AND REPLACED THE HOUSING. SET BACKLASH AND PINION DEPTH, REPLACED BEARINGS AND CUPS, REPLACED WHEEL SEALS. FILLED DIFF AND RE TESTED. VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 55 2D01 030008 4C2Z 9B742 A E29 69 65611
AWS Claim Key: 11155027 Trx Code: E72 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2009 Doc #:610576B
Cust Comments: C S CHECK ENGINE LIGHT IS ON AND TRANS TAKES ALONG TIME TO SHIFT AND AT TIMES SHIFTS HARD E29
Tech Comments: 65611 69.9B742 VERIFIED SES LIGHT IS ON. EEC TESTED, PERFORMED KOEO TEST AND PULLED CODES P0407 AND P0488. PERFORMED KOER TEST AND THE SAME CODES APPEARED AGAIN. PERFORMED DIESEL ENGINE DIAGNOSTIC SHEET. TEST DROVE, MONITORED AND RECORDED EGT THROTTLE PLATE PIDS WHILE TEST DRIVING AND FOUND THE THROTTLE PLATE IS STICKING OPEN. REPLACED THE THROTTLE BODY ASSEMBLY, TEST
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 56 5B03 050301 2C3Z 3254 AA L88 D8 66840
AWS Claim Key: 11155028 Trx Code: SPW Labor Hrs: 5
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2009 Doc #:611565A
Cust Comments: C S FLUID LEAK FRONT AXLE AREA L88
Tech Comments: 66840 D8.3254 VERIFIED FLUID LEAK IN THE FRONT AXLE AREA. FOUND THE INNER AXLE FLUID SEALS LEAKING. REMOVED BOTH FRONT AXLES, REMOVED DIFFERENTIAL CARRIER AND FOUND THE SEALS LEAKING. REPLACED BOTH INNER SEALS AND REINSTALLED ALL PARTS. FILLED DIFF AND RETESTED. VERIFIED REPAIRS.
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 57 5G02 040103 4C3Z 3049 DB N50 42 68087
AWS Claim Key: 11208900 Trx Code: 0701D Labor Hrs: 3.7
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2009 Doc #:612544D
Cust Comments: C S THERE IS A CREEKING NOISE IN FRONT END OVER BUMPS N50
Tech Comments: 68087 42 3049 VERIFY CREEKING NOISE IN FRONT FOUND SOURCE OF NOISE COMING FROM RH BALL JOINS AND SWAY BAR LINKS REPLACE RH UPPER AND LOWWER BALL JOINS AND SWAY BAR LINKYS CHECK TOE TEST DRIVE VERIFY REPAIR
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 57 5A06 050204 F81Z 4947 AA K02 42 68087
AWS Claim Key: 11208899 Trx Code: 0701D Labor Hrs: 3.9
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2009 Doc #:612544C
Cust Comments: C S THERE IS A POP NOISE IN REAR END UPON ACCEL OR DECEL.K02
Tech Comments: 68087 42 4947 VERIFY NOISE COMING FROM REAR DIFF REAR AXLE DIAG REMOVE REAR COVER FOUND CARRIER CLUTCH WORN REPLACE CLUTCH REASSEMBLE FLUSH HOUSING TESST DRIVE VERIFY REPAIR
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 57 2E03 031403 4C3Z 12B599 ABRM D02 42 68087
AWS Claim Key: 11217045 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2009 Doc #:612544A
Cust Comments: C S VEHICLE DIES WHILE DRIVING D02
Tech Comments: 68087 42 12B599 VERIFY CRANK NO START KOEO P0611 PINPONT TEST S1 S7 S8 FOUND DEFECTIVE FICM REPLACE FICM VERIFY STARTS IN RUNS BUT RUNS ROUGH KOER NO CODES MONITOR POWER BALANCE TEST FOUND INJECTORS #1,2 MISSFIRING FUEL PRESSURE TEST PASSED 51PSI RELITIVE COMPRESSION PASSED REPLACE BOTH INJECTORS TEST DRIVE RE EEC TEST VERIYF REPAIR
1FMSU45P95EA12986 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 03-AUG-2004 09-FEB-2005 152096 USA 58 7B02 140201 4C3Z 10V346 AARM D02 42 70314
AWS Claim Key: 11223212 Trx Code: SPW Labor Hrs: 1.8
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2009 Doc #:01797851
Cust Comments: CUST STATES BATTERY LIGHT IS COMING ON
Tech Comments: TEST CHARGING SYS 12.68V PINPOINT TEST REPLACE ALTERNATOR RETEST 14.26V. SERVICE INSTALLED PARTS ON 6 15 09 AT ACCURED MILES OF 10394, CROSS REF RO # 607597(SAMES CROW FORD LINC MERCURY)
