what rear tire pressure do you guys run in the rear dualls? I only use it to tow. most times im towing my 40 foot fifthwheel with 3,200 lb of pin weight.
the door says 60 psi and 75 front. oh btw it is a 08 f-350 4x4
Aimless Wanderer
I run 75psi in the rears and 55psi in the fronts. I have considerable more pin weight than your reference and have never had problems. Mine is a 1996 Dodge with over 200k on the clock. It is a work truck and not used for pleasure for the past 10 years.
