In the passing lane
Ok so we got a toy hauler a 2006 26' weekend warrior and i got an equalizer hitch to go with it. But when I have it hooked up when I turn the hitch makes some popping noises is this normal?
It's normal, sway bars make noise too. Whatever you do DON'T lubricate anything that's not supposed to be lubed.
In the passing lane
cool thanks the only i lubed was the where the bars go into the hitch:thumbsup:usflag
Remember to keep your balls covered and well lubed so they don't rust or bind
:D
Reactions: Kip
In the passing lane
ADMIN/MAFIA
when we had the travel trailer I ran the equalizer as well and it does pop and make noise but it is normal. I think in the directions it says that if you are in a real tight turn (like backing into camp sites) they recommend you take the bars off. I never had to do this but it is something to think about if you get into a real tight situation.
Reactions: Kip
