1 - 10 of 10 Posts
Hadley Coal Roller
how much work would be involved in swapping a 24v cummins into a 1995 dodge ram 1500.
Not too bad, be even easier if you swapped the whole chassis under your sheet metal...
not to bad. just like swapping a diesel into any other gasser.
Hadley Coal Roller
im not for sure on the specs. im not gonna be doing it. im trying to make sure it can be done so my buddy will buy it and i can mod the **** outta my stroke lol.
Born in the USA
Guy on PavementSucks.com did it. It does take a lot of work but it can be done.
Wiring actually isn't too bad, depending which version and how much automatic function is desired.
Born in the USA
I don't think the wiring is too bad if you have a complete donor truck and you swap everything over. But you never know....
EDIT: Guy on PS.Com (SuperHawk2002) did a 12v swap, not a 24v so I'm sure there will be more wiring to do in your case.
1 - 10 of 10 Posts
