Pretty please lol
VIN# 1FTNW21F72ED25026
oh ya it at all possible would like to find out by wednesday if possible. Not meaning to sound pushy or anything but I am more then likely going to be picking this truck up up if all works out. Thank you for your time have a great day everyone
OASIS RESULT:
1FTNW21F72ED25026
See bottom of the OASIS result for contact ID
02/06/2006
21:02:52
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/30/2002 BUILD DATE
05/17/2002 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
06/13/2005
DEALER: Melville Motors Ltd.
WARRANTY CLAIM NUMBER: 716066 ODOMETER: 121640K
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 9A332AA HOSE ASY (FUEL HIGH 001 MT9A332 D8 FAILED GASKET/SEAL
DIAG CONCERN REPLACED HI PREASSRE OIL SUPPLY LINE TO INJETORS HOSE LEAKING / /USING MT TIME AS NO PUBLISHED LAB TIME
END OF OASIS REPORT FOR 1FTNW21F72ED25026
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 8 2E06 030008 F6TZ 9F838 A D03 42 9294
AWS Claim Key: 4903683 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:12-MAR-2003 Doc #:70873702
Cust Comments: HARDSTART/NO START
Tech Comments: DIAG.INJ TEST,NGS TEST.DATA LIST MONITOR.GLOW PLUG TEST.FUEL CONTAM FUEL PRESSURE TEST.EEC TEST.PIN.RR ICP SENSOR,NOT READING ACCURATE.RETEST.
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 11 5O03 030008 2C3Z 9G804 AA L85 D8 15389
AWS Claim Key: 6009401 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2003 Doc #:70945501
Cust Comments: DIAGNOSE OIL LEAK
Tech Comments: DIAGNOSE .RR HIGH PRESSURE PUMP FITTING AND HOSE .RETEST.ROADTEST
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 11 * * * * * * * 15389
AWS Claim Key: 6009402 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:02-JUN-2003 Doc #:70945502
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 17 7B02 140201 2C3Z 10346 BARM C25 42 36029
AWS Claim Key: 8202409 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:24-NOV-2003 Doc #:71114401
Cust Comments: BATTERY DEAD HAVE TO BOOST TO START
Tech Comments: DIAG CONCERNALT NO GOOD REPLACED ALT AMPS LOWR
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 17 5G03 040103 2C3Z 3050 BA H21 33 36364
AWS Claim Key: 8300675 Trx Code: E84 Labor Hrs: 3.4
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:02-DEC-2003 Doc #:71123201
Cust Comments: STEERING WANDERS ON ROAD
Tech Comments: DIAG CONCERN REPLACED RITE UPPER AND LOWER BALL JOINTS
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 17 2E06 030402 F81Z 9A543 CRM D02 42 37011
AWS Claim Key: 8467482 Trx Code: S07 Labor Hrs: 5.4
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:12-DEC-2003 Doc #:71134301
Cust Comments: ENGINE WONT START WHEN HOT
Tech Comments: DIAG CONCERN REPLACED FAULTY IPR AND HI PREASSURE PUMP
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 19 7B02 140201 * 10346 * C26 42 37215
AWS Claim Key: 9010500 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:04-FEB-2004 Doc #:71177901
Cust Comments: ACCESSORIESDIM AND CUT OUT /ENGINE STALLS WONT RESTART
Tech Comments: DIAG CONCERN REPLACED ALT NOT CHARGING THIS IS NOT A REPEAT REPAIR THIS IS A FAILED PART
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 19 7B02 140201 * 10364 * C25 42 37242
AWS Claim Key: 9057726 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:10-FEB-2004 Doc #:71182801
Cust Comments: BATTERY GOING DEAD LITES ETC FLICKERING AND DIMMING WHILE DRIVING
Tech Comments: TESTED BATT AND CHARGING SYSTEM REPLACED ALT ONLY 12 VOLTS/28AMPS THIS IS NOT A REPEAT REPAIR PART FAILURE
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 19 7N02 010505 2C3Z 14528 CAC B43 33 37242
AWS Claim Key: 9057727 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:10-FEB-2004 Doc #:71182802
Cust Comments: PANEL AROUND SWITCHES ON DRIVERS DOOR LOOSE
Tech Comments: INSTALL SWITCH PANEL ON LEFT FRONT DOOR
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 19 7C01 01XXXX * 14018 * L26 42 37242
AWS Claim Key: 9057728 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:10-FEB-2004 Doc #:71182803
Cust Comments: DOOR AJAR LITE STAYS ON ALL THE TIME
Tech Comments: DIAG CONCERN REPLACED LEFT REAR DOOR AJAR SWITCH MT TIME NEEDED FOR EXTRA DIAG TO LOCAYE PROPER DOOR INTERMITENT
1FTNW21F72ED25026 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 17-MAY-2002 30-JUL-2002 4B4694 CAN 35 5S11 030008 F81Z 9A332 AA L65 D8 75583
AWS Claim Key: 13716168 Trx Code: E72 Labor Hrs: 1.5
Dlr Cd-Sub Cd: B4694 - * Name: MELVILLE MOTORS LTD. Ph: 306-7285458 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:13-JUN-2005 Doc #:71606601
Cust Comments: OIL LEAKING FROM ENGINE ENGINE SMOKING
Tech Comments: DIAG CONCERN REPLACED HI PREASSRE OIL SUPPLY LINE TO INJETORS HOSE LEAKING //USING MT TIME AS NO PUBLISHED LAB TIME
thanx very much
