OASIS RESULT:
1FTXW43RX8EA38025
03/04/2008
20:46:31
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-450 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/01/2007 BUILD DATE
02/19/2007 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0968 - USA 2007 NEW 48/100000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: TRACEY SAVICH
OPTIONS:
EXPIRATION DATE: 04/01/2011
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 02677
ESP CONTRACT START DATE: 04/01/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
11/28/2007
DEALER: South Bay Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 148932 ODOMETER: 022501M
LABOR OP
CONDITION CODE
CONDITION DESC
NPF NO PROBLEM FOUND (NR 000 NPF 82 FREIGHT/POSTAGE/MAINTENANCE
LOW FLUID EEC TEST PASS,ROAD TEST WHILE MONETORING TRANS PIDS,ALL NORMAL OPERATIONS,CHECK FLUID LEVEL AND CONDITION,FOUND LEVEL 1QTS LOW.TOP OFF FLUI D ROAD TEST CHECK FOR LEAKES NO LEAKE FOUND.OK AT THIS TIME.
11/28/2007
LABOR OP
CONDITION CODE
CONDITION DESC
TAP1 MISC 000 82 FREIGHT/POSTAGE/MAINTENANCE
TRANSPORTATION ASSISTANCE INVOICE 313118
11/28/2007
LABOR OP
CONDITION CODE
CONDITION DESC
XY 75W140QL 003 4010D 42 DOES NOT OPERATE PROPERLY
7C3Z 4R602HL DRV/SHFT & CPL ASY 001 071603A
XL 3 002
1 VARIFIED CONCERN ON TEST DRIVE REMOVED DRIVE SHAFT AXLES AND COVER WITH GEARS FOUND EXCESSIVE BACKLASH ADJUSTED BACKLASH REINSTALLED COVER WITH GEA RS AXLES DRIVE SHAFT RETEST DROVE NOISE STILL PRESENT REPLACED DRIVE SHAFT P ER TSB 071603A NOISE STILL PRESENT RECOMMEND DIFFERENTIAL OVERHAUL REPLACE R ING PINION AND ALL BEARINGS
10/15/2007
WARRANTY CLAIM NUMBER: 145246 ODOMETER: 018994M
LABOR OP
CONDITION CODE
CONDITION DESC
TAP3 RENTAL - LINC LESS S 007 82 FREIGHT/POSTAGE/MAINTENANCE
NESSARY TO PERFORM R-T W- CUST FOR NOISE PIN PIONTING, POSSIBLE NOISE IS FRO M THE TRANSFER CASE GEAR CLASH, NORMAL TRANSPORATION ASSISTANCE INVOICE 31 2746
10/15/2007
LABOR OP
CONDITION CODE
CONDITION DESC
PCM OUTDATED. PERFOREMD TRANS ELECTRIAL DIAG, FOUND TEH SHIFT POINT SLOW TO RESPEND. RECAL PCM-TCM, CLUSTER & RETSTED, PASS SELT TESTS ON CONTROL MOD S ALL PASS. NO DCT PRESENT AT THIS TIME.
10/15/2007
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8009B RADIATOR & SUPP ASY 001 8005D D1 POROSITY
VC 7B 004 8005A
CASE OF RADIATOR LEAKING. VERIFIED CONCERN, PERFORM,ED COOLING SYS PRESSU RE TEST. TRACE THE LEAK TO RADIATOR REPALCED & RETESTED, PASS.
08/13/2007
WARRANTY CLAIM NUMBER: 139014 ODOMETER: 014011M
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 2268F TUBE ASY-RR BRAKE 001 MT2000A D1 POROSITY
000 2078AB
LEAKING BRAKE LINE AT THE L-R OF REAR AXLE. VERIFIED CONCERN. PEROFMRED I NSPECT. FOUND BRAKE LINE LEAKING. REPALCED TEH LINE & BLEED BRAKES. RETESTED PASS.
08/13/2007
LABOR OP
CONDITION CODE
CONDITION DESC
13207 BODY ASY PARK LAMP 000 999A 33 LOOSE PART
REINSTALLED TEH MARKER LAMP.
03/23/2007
DEALER: Advantage Ford
WARRANTY CLAIM NUMBER: 176192 ODOMETER: 000006M
LABOR OP
CONDITION CODE
CONDITION DESC
000 07S49B
RECALIBRATED PCM AND RETESTED PER 07S49. 8.52 9.54.
| On-line 1878
END OF OASIS REPORT FOR 1FTXW43RX8EA38025
