TDG #97
I have looked everywhere to find the correct tire pressure for my tires...
Kuhmo MT 37x13.5x22...
So if anyone has any insight... should I just use the stock tire pressure?
I am going o a decent length trip today and want to check out my tire pressure before we head off....
Thanks!
I'm not sure what the max cold pressure is on your new tires, but when I got new ones, it was a bit less than the 80psi max stock. On 38x15.50's I run 50psi front (max cold) and 35 rear. Checked with chalk. Might be able to get away with about 5psi less all around, but there seems to be even contact from the chalk test, and driving on dirt then back to pavement. I'd rather error slighly on the high side, without going over the tires max spec.
