Ok, so I am just about complete with all my repair's. I start it up, perfectly, no hesitation nothing..But the key won't shut it off..Which is all new last year..SO, I shut off my batteries, still running. I disconnect the fuel pump, BOTH wires, still running..Ok, what's left? Alternator, NOPE I disconnected BOTH POS/NEG..still running. I had to stall it out..This has happened before and I cut the frame side wire and it stopped, no more.
Questions(s):
Is there possibly something that won't let the engine shut off until possibly oil temp is up to a predetermined level ? I think not since there is no computer..
Is there a reverse voltage through ground that allows it to continue to run when all possible electrical connections are removed, ie Batteries and Alternator?
Little help here, diesel isn't getting any cheaper....:help
I should ad, I hear the solenoid click on the outside (frame side) of the pump when I put power to it when I am trying to troubleshoot this issue..as in power applied/removed. Thanks for the help..
Questions(s):
