1 - 11 of 11 Posts
Just picked up a 99 KW W900 with the cat c12 9NS under the hood. The engine has a full overhaul with less then 80k on it but the previous owner never replaced the turbo. Since it has a non wastegated Pp turbo that has 700,000 on there I was wondering if anyone has any experience with a turbo upgrade such as the BW S400Sx-75 on a C12. I believe it is a bit larger on both sides the the PP and I will have to do some research as to the proper tune but I am looking for some advice if anyone has any...
Borg 171702 is a great upgrade on the 12.7 detroit.
Cant see it being any diffrence on a c12.
Maybe a 171701 for the c12. Its got a bit small comp wheel , might work better on the slightly smaller c12
Thanks Swaan! I have heard good things about that particular turbo with the Detroits that's why I thought it might possibly make a good fit for the c12 as well...
Don't have any experience with a C12, but knowing that there is a 1.15 divided housing for the 96mm turbine in the 171702 it gives you an option should it be too laggy.
Another option might be a 174260, this should be a 75mm turbo with a slightly smaller turbine and a 1.10 wastegated turbine
What did you end up going with? I am a turbo n00b. I have a 410 2KS that I'm looking to do the turbo/manifold/program thing. Looking for efficient power. Running a 10 speed in hilly PA. Will probably get the work and program done at Martin's. Are those 2 turbos mentioned bigger than the Pittsburgh Power?
Forgot to mention on a budget! I see I can get the 171702 on eBay for $500 :surprise: Regarding budget that also means I can't afford to blow it up!
I went with the 171702. Truck still isn't on the road yet I decided to do a frame up restoration and it's taking time so I can't give any feedback as to how it work. I need a computer upgrade first before I take it out and really put it through the paces... can anyone put me in touch with Mr. Haney? I havnt had any luck with PMs
Pete379SH how did you make out with your turbo on your C12? Buddy runs the same engine and might need to replace his turbo soon. His is a 410 2KS engine as well.
1 - 11 of 11 Posts
