Cam and crank sync code comes on and off.When it becomes active engine loses all power and sounds like a rattle snake.Then if you let off the throttle it will recover than start all over.Changed both sensors.Fuel pressure is 70 at idle and 95 steady under load.Checked back lash on timing gears.Between crank and all idlers and cam its.045 and between idlers only its.10.Is that to much and throwing the code causing the engine to act like this?
