03 f350 xl 7.3 2wd x-tend
:shrug: how hard is the cold air, i herd can be a ***** due to the cutting of fan shrowd. at least that is what my dad was told when installed on his 04 6L. mine is an 03 7.3 2wd. I also want to install the exhuast myself. I have some expierience from schooling and when i was a mech. at u-haul working on there 7.3's in there internationals. But of course i won't have the big bumper jack we had to get the clearence under my truck. what, a whole weekend? thax any input greatly appriciated. :smoke :woot:
Cold Air on a 7.3 is a piece of cake. Completely different setup than on a 6.0. The exhaust isn't bad either. If it is going to replace the downpipe too, a reciprocating saw would be helpful.
TDG MAFIA #94
put a reply in your other thread in the other forum... others too
The AFE stage 2 only takes about 30 min for someone with out much mechanical experience. The exhaust will be easier than the 6.0 was. I think you will be ok to do it your self.
I thank you all
:damnit sorry i cant respond faster my 2yr old took all my keys off my comp. it really makes it hard to type.:nunu: :nunu: :nunu: :pissed: :crybaby2: :ph :shootself: :cry:
Ditto. Just did mine last night in the driveway with the hood light, a small flashlight in about that timeframe. Easy cheese. Can let you you know about the exhaust tomorrow. :cool:
You should be very happy with it, especially once you finish your exhaust. What else do you have done to your truck?
I installed 4 inch exhaust on my 7.3 and the only problem i had was the old factory tailpipe rubber mounts were not in the correct location for my new muffler, had to redrill in the frame to line everything up,, work good now,,,,,,one other thing, i didn't take off the tranny heat shield and the stupid thing rattles sometimes had to wire it real tight, make sure you do that first,,,
I DRIFT DIESELS
i put the 5 inch turbo back from jegs on my truck, took about 4 hours by myself, the downpipe was the hardest thing.
