I installed my ts chip with php tunes on. My issue is on 80hp daily driver it runs great but on 100hp race or the somke setting its almost like missing and doesnt nearly get up and go as fast. I just changed the oil and fuel filter thinking that might help but it didnt. Any thoughts?
thats how my dp was at first, it ended up being my fuel pressure, and a little problem with oil pressure as well.
What was the fix?
james down at dp tuner told me to check fuel pressure..and sure enough it was extrmely low. so i had to get a new lift pump.
My guess would be you are running out of oil on the higher settings as well. I would search for a good 17* hpop or start saving for an upgraded hpop (Stealth, Terminator, Adrenaline, etc)
Did did lift pump and regulator shim. Didnt make a whole lot of diffrence.:damnit
