My stock clutch will not quite hold at high power. I am running the Spartan
210. I need something a little stronger, but easy to drive. What is good? Can I change out the clutch with out lifting the cab?
Thanks
I have the South Bend single disk clutch rated for 450HP, part number 1950-64CBK, at http://www.thoroughbreddiesel.com/south-bend/powerstroke-single-disk.htm
It has ceramic buttons on the disk so some times it's a little noisy. It comes with everything. Flywheel, throwout bearing etc. I don't run the HP you do, but pulling my 9600lb 5ver will not slip it. Yes you can replace the clutch with lifting the cab.
TDG Mafia Member #25
I wanna do that here soon, but I've got so many projects going on already. Been just runnin' the 150 tune for that reason.
Adrianspeeder
