I got these codes today when i checked my truck. top four are P pcu, bottom three are P ecu. These came outta nowhere whats the problem
P0500
P1694
P1693
P1687
P1693
P1698
P0501
Official TDG Doctor
P0500- No Vehicle Speed Sensor Signal
P1694- No BUS Message Received from ECM Module
P1693- DTC Detected in Companion JTEC Module
P1687- No Cluster BUS Message
P1698- No CCD/J1850 Message From TCM/PCM
P0501- Vehicle Speed Sensor Performance
Is the truck acting up any? How are all of your connections under the hood? Has anything gotten wet?
Nathaniel
I had just washed my truck when it had happened. I pulled out of the bank in first gear and it just burped and everything has been fine since then. Thanks for the help though
Go get a tube of di-electric grease and pull ever connector apart and put a dab of grease in every connector. It will stop that problem...
As a matter of fact I'm due for the same thing...:damnit
