Truck won't start unless plugged in. When it's plugged in it starts right up. I replaced the GPR a couple months ago so I checked it with a multi meter and it was fine. I unplugged the UVC harness plugs and check the glow plug pins with a test light and I had one bad glow plug. I also had 1 UVC harness plug that the outside pins where burnt. So that gives me 3 glow plugs not working on the passenger side. I would think it would start with 5 glow plugs working. What else can I check? Sorry this is so long but I'm kind of stumped right now.
The issues you found are your problem. With just 1 GP that isn't functioning correctly it makes cold starts very hard. With 3 I am sure it would be near impossible to start in the cold.
Discussion Starter · #3 ·
Thanks Eric. I wasn't sure about the number of glow plugs that would actually still start the truck.
