i recently had a flush and fill done on my 02 powerstroke. i have read the posts, searched and not found an answer to my question. i refilled with rotella extended life. it is orange colored. do i have to do the additive or not. also the testing that is done. the mechanic told me it is for pH. is this correct and what should it be.
Does it say it is recommended for Ford diesel's?
Most ELC u do not need to use the additive, but u will need to check it at a later time to determine if some needs to be added, IIRC
Reactions: buffalobob
TDG MAFIA #101
Agreed, look in the manual for the truck, and it will tell you the recomended fluids for your truck, the coolant bottle might even say it.
Dieselis' Maximus
IIRC correctly its also on the cap of my 02 radiator overflow/fill bottle.
