1 - 13 of 13 Posts
no clue
What the F*** happened to that thing in the first video? It sounded like someone threw black cats in your exhaust...... Are you still trying to run a lockup program in 4 hi? Also did you have the motor up to full operating temp when you tried to pull the first time? You need to bump up the idle to get the combustion chamber hot.
ha!i got to see it in person,:popcorn: Good job fuzzy
Dang, the smoke cleans up pretty good at WOT! Sweet videos fuzzy.
thanks everyone. not sure what the problem was. i will figure it out though
this took place in brookfield ny
F
Who was that screaming in the background LOL
Looks alot better than the first pull you posted! Good Job!
Discussion Starter #12
these videos are the same.
Supporting Vendor
Fuzzy, has your truck ever pulled good in low range? That should be a good advantage w/ the 5R, and shifting the 1st three gears if you can stay on top of the turbo, kinda like the Dmax boys. Bars look like they are working good, truck looks smooth going down the track.
1 - 13 of 13 Posts
