Vendor
One of the many appealing things about owning a truck is the array of unlimited possibilities you get with it, like hauling, towing and off-roading. If you're a fan of the lifted off-road trucks than upgrading it with a good quality aftermarket lift kit is the right solution and today we are here to present you 2 new options from CST Performance Suspension, designed specifically for Silverado/Sierra owners.
Being a leading manufacturer of lift kits for GM trucks for over a decade, these guys have developed top of the line solutions for 1500, 2500 and 3500 models. Their kits will ensure excellent performance, increased ride quality and comfort needed for a smooth, stable, and dynamic ride.
CST Performance Suspension 6"-8" x 4" Adjustable Stage 1 Front and Rear Suspension Lift Kit at CARiD
Features:
- Material: 1/4" or Thicker Steel
- Finish: Two-stage gloss black powder coat
- Designed to improve your vehicle's performance on off-road terrains
- Made to give you the ground clearance you need to install bigger tires
- Crafted using only the strongest materials to provide exceptional durability
- Proven to deliver excellent resistance to corrosion and wear
- Includes 1-piece sub-frame, fabricated steering knuckles, steering drop.
CST Performance Suspension S.T.L. High Clearance™ Suspension Lift Kit at CARiD
Features:
- From 3-6" adjustable lift up to 6-8" adjustable lift
- Constructed of 1/4" or thicker steel for extreme strength
- Spindles are constructed of precision laser cut 1/4" or thicker steel with cnc machined ball joint tapers, and than completely mig welded
- Improved ride from the factory
- Ability to be put back to stock
- Guaranteed to add a rugged off-road look to your vehicle
- No GM stabilitrack issues
- No welding required.
Except for the kits above you can also find many other lift solutions for Silverado/Sierra on this page.
Simply plug in the year make and model of your truck and our website will list all available options!
Lift your Chevy/GMC with CST Suspension Lift Kits and enjoy safe and comfortable driving!
