Item 1: Less than 25k Miles on a 450HP @ 850 ft lbs of torque 5.9 liter Cummins 12V out of frame engine rebuild but Cummins authorize dealer. Reabuild included all upper & lower gasket kits, oil pump, piston & liners, head, front & rear structures, lower bearing set and all machine work. Performance parts added include HX-35 turbo, marine camshaft, stage 3 injectors and P-7100 fuel pump. All new peripheral including upper & lower brackets & mounts, starter, alternator, fan hub, P/S pump, A/C pump, and South Bend 1947 high torque clutch
Price: $8,500.00
Item 2: Less than 10K Miles on a NV-5600 Re-man 6 Speed Transmission. Transmission is complete with MP205 Transfer Case and all adapter parts
Price: $3,000.00
Item 3: Set of Re-Man Dana Axles from 92 Dodge 3/4 ton P/U (3:55 ratio). Dana 60 Front axle complete with X-Over Steering. Rear Dana 70 Axle
Price: $3,000.00/Pair
Item 4: Set of (4) 37" Toyo Open Country M/T (25% Tread) on a set of Race Line 17x10 Aluminum Wheels:
Price: $600.00/set
Item 5: Skyjacker 6" Complete lift with shocks and all mounting hardware
Price: $600.00/set
For additional information call 541/267-6990 xt. 107 or email [email protected]
