Ladies & Gentleman, I am looking to get the following in the following order. Someone recommended I post in here. Appreciate the help. Depending on my cash flow, I will purchase these unless there is a better recommendation as I am new to diesels. I recently purchased a 2003 Dodge 2500 with a 5.9 Cummins. It does not have the HO if that matters. Thanks, Undetermined
1. AFE Stage 2 XP Mega Cannon Air Intake Kit for 2003-2009 Dodge 5.9L/6.7L Cummins, AFE-75-11342 Pro-Guard 7 (Value Pack)
2. ISSPRO EV Gauge Kit, 2003 24 Valve Dodge Cummins, Pyro, Boost, and Trans Temp , Full A-Pillar 3-Gauge Mount 03-09 RAM, Taupe Gray ABS, White Dial, Black Bezel, Red Pointer, 60 LB Boost gauge, WeatherPack
3. MADS Electronics SMARTY Jr. for 2003-2007 Dodge Cummins 5.9L
4. AFE Large Bore HD Aluminized Exhaust System for 2003-2004 Dodge 5.9L Cummins, 4 Inch Turbo Back Off Road
4-1/2 MBRP Black Bolt on Tip, Single Wall, Angle Cut, Rolled Edge, 4-Inch Inlet, 5-Inch Outside Diameter, 12-Inch Length, Bolt On
