HAYMAFIA
i have a 97 western star with a bad engine. it has the 460 celect plus engine in it now. will a cummins celect engine go in its place?
;)yes i don't see no problem!!!celect plus 460 to525 (metal pistons) celect only 435 to460(aluminum piston)watch the ecm plugs:shrugs
i beleive the plugs are the same, but the wiring is different. i think the celect ecm uses a seperate ground for the sensors and the celect plus has a common ground tiring all the sensors to one ground through the ecm. i'd say you would have to change the harness:gaah......
i should have read your post better, if you just swapping engines, then you should be good, just have to use the electronics and the ecm on the engine you have now i think....
