Hi. I need some advice. Someone can helpme. I working on a volvo 96 I repalce the engine whit a m11 celect ecm but the original wiring harness from the truck was froma celect plus ecm so I can plug the celect . So I install the celect plus ecm on the new engine but I can start , put some ether and nothing , that's I need some help . What its the diference on a celect and a celect plus both engines are m11
I looked up just a few connections for the OEM connector and they are in different positions. You will need a printout for the old CPL and the new one to reposition the pins in the proper place going from a Celect to a Celect Plus. Then you will need the little tool to push out the pins.
