I am looking for a complete kit with upgraded axle shafts, limited slip, and installation kit for a Dana 70 rear with a 4.10 ratio. Axle is in an 01 Dodge 2500 4x4
Anyone have anything?
I also have been looking for the same stuff. Many have told me to call Moser engineering and ask them. More than likely it will be custom, because there isnt that big of a market for the 70, most upgrade the 80 (haisley machine has axles and such for the 80)
Also been told that Yukon gear makes stuff, but I havent yet checked with them.
Mikey
The reason being is that the 70 uses the same weenie pinion as a 60... The spline diameter is tiny... and they tend to twist off.
Haulin' Hay
If none of the vendors here have anything to offer, check out Randys Ring & Pinion. They can most likely help you out.
tearer upper
i believe Dynatrac is also doing some 80 stuff, so they might have something for your 70.
