resident mason
I'm looking for some prices / availability on a Detroit Locker or Truetrac for a Dana 80 from a 1997 f350 dually. Probably 373's but have to confirm that. Also does anyone know where in the vin# ratio's are coded? The tag on axle is rusted and looking for easier method than jacking it up and counting revs.
Do you want a locking carrier only or would you be interested in a whole axle housing drum to drum?
FYI, I believe that Ford began using the 3.73 gears with the Super Duties. I would imagine that they are 4.10 or higher, however they could be 3.55's. Chris
resident mason
I'm running vin# through dealer to find out. I'm probably going to leave the center section open for now just put in new ring and pinion to get me through winter.. The pinion in it has a busted tooth.
