I'm looking at getting a programmer, the problem is the dealership. I've read several things like disconnecting the battery so that it clears everything except the battery disconnect code. Then drive it around for about 20 miles. Does this ready work? I've read in other forums that is doesn't matter, if they dig deep enough they will find the signs of it being programmed. The only problem I'm worried about is the stupid head gasket issue. If I blow it out with the programmer, good, I can get the right stuff in it so it doesn't happen again. Bad if they void the warranty b/c they find signs of the program. What is the truth? They get you coming and going!!! :damnit
