Yes I am stupid. Stressed out, I put about a quart in the gas tank. I did NOT turn the engine on. I disconnected BOTH batteries to my 2016 Ford F250 then I put the truck in neutral (inside steering column) so we could roll the truck up onto the tow truck to take it to Ford.
Ford is still analyzing, but telling me basically this is a 10-12K fix for the ENTIRE fuel system. I read/and was told, if the fuel pump has NO power, it can not cycle and so the only bad fuel SHOULD be in the tank.
NOTE: I DID turn the key AFTER the batteries were disconnected to unlock the steering wheel so we could guid the truck up onto the bed. But again, BOTH batteries were disonnected first.
Am I really screwed or should most of the work be cleaning up the tank and ????.
Thanks
Thanks
