Hey guys i need some delivery valves for a 1994 cummins 12 valve
thanks
What size? 181 DVs can flow enough fuel for 800hp, as long as the pump ibuilt up right.
Well my pump is stock but new and i have marine 370 injectors...i plan on gettin a 4gsk also fuel plate is #0 an full forward and afc forward......what do you recommend ?? i am also eventually goin to get timming done... thaks
These are Moderate Valves:
High Flow 191 Delivery Valves
For 1994-1998 P7100 Pumps Found on Dodge 12V Cummins Turbo Diesels.
They don't flow as much as laser cuts, but they are a definate improvement over your stock delivery valves!
and These are Extreme for $30 more:
High Flow Laser Cut Delivery Valves by SCHEID Diesel
For the P7100 Injection Pump found on 94-98 Dodge 12 Valve Cummins Turbo Diesel.
These delivery valves have shown gains of 100HP over stock delivery valves.
If you need pricing shoot me a PM
How much of a gain are the 191's? those are just honed out arent they?
You should expect a 50-60 hp gains with the 191's. Not sure what the process used to make or modify them though!
With 191's you wont notice much difference in a 96' up pump(stick or auto), they already have 181's in them, maybe 5-10hp:shrug: . The laser cuts, or custom cuts like mine are awesome(who knows what hp with these!!) If you have a 94-95 pump then the 191's will show a nice improvement 30-60 hp, because the 131's found in these pumps are pretty "stock", if you will.
Mikey
