Whats the diffrence between the two?
the comp defuels at 2700 RPMS, and with the Drag it doesn't defuel until 3200 RPMS. Therefore you get the power sooner.
well the power stays on longer is what it really boils down to. The drag comp offers about 20-30hp above the regular comp box, on the topend of the spectrum. Also, the fact that it doesn't defuel as soon, gives you a higher rpm range. Definitely worth the extra hundred bucks. I've switched back and forth with my friend that has a regular comp to see what the difference is like, and it is worth it IMO.
TDG Mafia Member #21
I just upgraded mine. It is definatly worth it. It fuels much harder while accelerating throught the gears and gives you that little extra up top. It is probably the best $125 mod you can buy.
