1 - 20 of 62 Posts
Automotive Lighting Experts
Discussion Starter · #1 · (Edited)
Diode Dynamics Fog Light LED Bulbs! Several Brightness Options! Plug & Play Install!
Silverado / Sierra Fog Light LED Bulbs
GMC Sierra / Chevy Silverado Fog Light LEDs - YouTube
We carry LED bulbs for replacement of your fog lights or DRLs, in all major sizes. This will make your truck's fog lights a nice bright white, without the hassle of HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year full warranty.
We also offer four options in brightness:
  • HP48: 265 lumens. Lower than factory brightness. Least expensive way to get the clean LED look
  • XP80: 510 lumens. Several times brighter than OEM. Will provide usable light output. Shown in pictures above
  • XML2: 1,420 lumens, our brightest LED replacement
*XML2 is available in 3000K Yellow / 4000K / 5000K / 6000K Color Temperatures
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your truck).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Sierra Fog Light LEDs
***We also have RGB Multicolor Options available for both models***
Any questions, feel free to ask via email ([email protected]), Post, PM or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
Discussion Starter · #4 ·
Do you sell LED headlights too?
Thank you for asking!
We constantly have customers ask about using LED bulbs in low-beam headlight applications. I just took these shots for a customer, to show them why the LED bulbs on the market are still not a good option, even when using a halogen projector, like that found on the Scion FR-S.
Most companies selling these products for low beam application show very poor comparison pictures, where they are washed out so you can't actually see the beam pattern. They claim that the output is good. The real pictures below tell a very different story.
Cutoff doesn't matter. Many companies justify that the output of their LEDs is OK, just because there is a cutoff line. Sure, you don't want light sprayed everywhere, but more importantly, you need light focused properly. As you can see, the factory halogen light is focused into a very tight beam, with a hotspot right at the center, which shines light far down the road. This is key to performance and visibility. You want all of the light focused right in the center, with a small area to the sides also illuminated, and just a bit below.
Total lumen numbers don't matter ...unless it's focused. Many sellers claim high lumen numbers, telling you the output is higher than halogen. In reality, the total output is usually about the same as halogen, and sometimes it's a bit higher. But since it is not being focused where it should be, the end result is that your visibility will decrease. It doesn't matter how much light you have if it isn't going in the right direction. As you can see, if you use an LED bulb for your headlights, you'll get some light output, but it will not shine very far down the road because it is not being focused into a hotspot at the proper location.
Just for comparison, we included a standard HID output. With HID, you get a focused beam, and a lot of light, so there is indeed a significant improvement in visibility. However, you do add quite a bit of light everywhere as well, including some on the top end. The main problem with HID is when it is installed into reflector housings, and the factory optic cannot direct this extra light properly. However, the projectors in the FR-S are quite good.
Summary: when you're looking at your low beams, an upgrade to OEM HID headlights is the best option, but an HID conversion is still a much better choice in terms of output and visibility compared to the LED bulbs on the market.
Of course, these LED bulbs are still a great option when you don't need focused light- such as high beams or fog lights.
Paul
Product Development
Diode Dynamics
Discussion Starter · #6 ·
http://www.youtube.com/watch?v=hn6Re02LRUw
Diode Dynamics: NEW! Stage Series Light Bars
Introducing STAGE SERIES LED lighting! Inspired by the needs of a professional rally driver, these light bars have been designed for maximum functionality, with compact size, cutting-edge TIR optics, and a useful beam pattern, all in a highly durable package.
-Advanced TIR (total internal reflection) optic
-Slim design, for easy mounting
-Available in driving or wide beam patterns
1 - 20 of 62 Posts
