1 - 11 of 11 Posts
i just recently ordered a holset WH1E turbo, because i had a mishap with my WH1C is the WH1E bigger and better or smaller and worse?
I think it's bigger, but why did you buy when you didn't know what it was?
Discussion Starter · #3 ·
because i asked the seller if it would bolt up and and i had to have something because i have to to go college and my moms expedition is a gas hog. plus, try driving a cummins without a turbo.......NOT FUN
its the same thing as an HX40
Discussion Starter · #5 ·
considering what i have done to my truck (sig.), will it still make the same power or better? will it be sluggish or spool up faster?
I'd think she'd spool fine. More power too.
it will spool ok depending on what size exhaust housing you got, what size is it
Given the plate you have, you might be alright with spool up. Will probably have more smoke and higher EGTs if you can't spool it good.
do you know what size housing you got on it
Discussion Starter · #10 ·
no, not sure
find out, do you have the turbo in hand? if so it will be stamped on the exhaust housing somewhere, either outside or inside of it
1 - 11 of 11 Posts
