Whenever my check engine light comes on because of my apps cutting out, I check and clear the codes I always find an Overboost code as well. Does the Apps have anything to do with that?
Sounds like you need a boost fooler. Sounds like its defueling real hard to keep the boost in check. I had a similar prob when I was in the process if switching boxes I left my j-hook on and kept loosin power. Thought it was the APPS for a hot minute but then remembered when I saw the overboost fault.
No... The only way to get a over boost code is to have a boost elbow without a boost fooler. Or your wastegate is stuck close.
APPS is your throttle... And MAP and Wastegate are you boost codes...
