Can anyone tell me how to remove the door panels on my dads 2004 F-150? I'm converting the regular mirrors to the LED type so he can see if his turn signals are on! Thanks Bryan
The plastic piece behind the mirror pops straight off. The window switch panel also pops up from the front and the slide it forward. Unplug the switches (they only go back one way too) Remove the screw inside that panel. I think it's an 8mm. Pop off the red lens on the lower portion of the panel and remove the screw there too then lift the panel straight up then off.
