1 - 12 of 12 Posts
Can't find the door seal mod thread. What size tubing was used?
I used the solid foam but think the tubing is a better choice. The foam can break while you are trying to snake it through and after a time it becomes "smashed" flat. I'm not convinced that it is working quite as good as it did when I first put it in but it still works. Sometimes I think I can here more noise than I did 6 months ago. Might just be me. I did it over a year ago.
********* and Mafia #90
It must have been lost in the hack..
its just 3/8" Vinyl Tubing. pull the door seals off, fish something threw the seals(small fish tape will work), then if you drill a small hole in the end of the tube you can tied a small string to the hose and to what ever you fished threw your seal, lube the vinyl with soap or a white lithium grease and pull it threw.. repeat for all others..
Bill, Have you did this does it work?
Not yet and i hear it works GREAT. I think Bushpilot did the write up for it but was lost in the hack :damnit
Everything i read on Google about it seems positive..
Ok time to spend more money:happymugs
SLAPS President
I have...nearly 60 feet of it in my crewcab....it made a BIGGER DIFFERENCE
in blocking wind noise than COATING MY ENTIRE TRUCK w/ HUSH MAT (aka dyna mat).
the wind noise is particularly loud at the drivers A-Pillar...and tightening up
the door seal/weather strip w/ poly tube eliminates the wind noise !
KEE KEE WHOO!
dons set up is very good, you cant hear crap....
its just a nice ride without excess noise goin on.
Reactions: bushpilot
1 - 12 of 12 Posts
