the dot(bit) inspection is a little different about level 1 which they do in the scales, but i can give you a tip ,(any way you have for 3 year for IRS)you need to show all the log books for a year the inspector compares your log book with your payroll + miles
they will ask you a inspection for 90 days for a mechanic authorize(4 inspection for year maintenance) ,they will also test you drugs and alcohol ,also inspect your brakes the cutting and cut out(verbal test) all the alarms have to work this inspection ,(clean under carrier) they can do it in your house or the company you work in with appointment if you are 0/0 need show your CA current ,road taxes ,insurance, and registration:usflag
