1 - 10 of 10 Posts
I was thinking about changing my downpipe to the 4". How hard is this to do? I red you have to cut the stock one out therefore if i have to change my truck back to stock to go to dealer what would i do? Any advise or direction would be greatly appreciated. Also who makes the best downpipe fit and performance wise?
It's not hard to do. Just cut your stk pipe off up as far as u can, it's garbage afterwards. Remove the band clamp connecting it to the turbo and pull it down. Powerstroker67 2 piece ceramic coated pipe is probably your best fit and finish, That's what I went with. got it at rudy's diesel performance, Talk to gab he'll fix u up
thanks for reply venom. decided not to change downpipe since i only got 16k miles on truck. Never know when you got to go visit dealership
If I remember the standard down pipe is 4"OD, but is sleeved with 3.5" pipe for heat reasons. I have heard, but have not seen, that the 4" down pipe you purchase would look the same on the outside but would not have a 3.5 inch pipe inside of it. Anyone verify this?
correct, the stk pipe is double walled. i'm pretty sure all aftermarket ones r single wall 4".
They may not deny warranty for DP, but they may start poking around and looking harder for other custom work that had been done because of it.
Soooo, what are the gains by doing this mod??? My truck seems to be loud when its cold at the down pipe area and intake seems louder too. Factory down pipe cracked?? I cant seem to see any problems. 210 tune,afe intake, No dpf.
The engine will spool up faster because it can breath easier. Once you see the inside of the factory pipe you will see what I mean. Looks like the inner pipe was installed with a crow bar.
1 - 10 of 10 Posts
