I just received my DP-Tuner. I installed the chip and mounted the f-5 switch like the picture in the instructions showed. I was thinking about mounting the switch different, but I couldn't decide where to put it. Anybody have a creative way of mounting the switch? If so, could you please post some pictures?
TDG Mafia Member # 37
I mounted mine right next to the 4x4 selector switch. I pulled the cover to make sure I would not hit or cut into anything first, then I drilled four 1/8 inch holes and just cut from hole to hole in a rectangular pattern the size of the back of the F5 selector switch. I made it slightly smaller and then filed it to fit real snug so it would not fall out. Here is a pic. View attachment 12756 Hope this helps ya. Gene :mafia
