Does anyone have any experience with DP Tunes installed on the EVO 2 ? ANy commenets would be appreciated.
Thanks
and your experience was ? good, bad
Sorry, I was being a little facetious. I work for Edge and had helped DP-Tuner get set up as the Custom Programming Dealer for the Evo2. I am probably not the most objective person to ask, but there are definitely some advantages to running Jody's tunes in the Evo2. The only disadvantage is that you can't shift on the fly.
Hopefully someone will drop by and reply on the results they have had with the Evo2.
Take care and good luck.
Bill
srauner,
make sure you anwser YES to rewite stock tune and it should allow you to continue to upload custom tunes.
