1 - 12 of 12 Posts
I was wondering what kind of RPMs does this combo have.. I have heard that this fuels over 3300 but I have not heard for sure what type of rpms that this combo has.. does anyone have any experience with this combination..???
3700RPM twice with the Drag Comp and a MAD ECM with full timing, without the MAD ECM now I think it is around 3500-3600RPM. I was not a fan of the stack, the truck yanks the sled better now.
TDG Mafia Member #21
I have seen a few guys actually loose power on the dyno with that combo. Bouncer relayed to me that they recommend stacking the smarty with a tst only. I guess the programs work together better than they do with the Edge.
I ran the smarty on #8 and the drag comp on 5/5 and my truck turned over 4000.
So I guess you like this setup.. That is what I want to turn 4000 rpms.
Cummins Man
I know that you will loose top end Hp but gain a much wider power band up through the RPM's from what I have heard on other sites. I think it was like 11hp topend lose but power came on really quick, with a nice wide power band.
Andy
B
The Smarty removes the rev limiter. D_B has had his truck to 4k with his Smarty only.
Yah I was going to ask, isn't 4k pretty high for a stock motor?
I sure it has a little wear on the motor but I am not worried about my valves clapping hands with my pistons, or my internals coming apart.. I read that a stock Cummins Crankshaft doesnt start to come apart until 5600 rpms.. So I think that it will be fine.. I am not saying dont get stiffer springs but the stock ones should be fine.. Hopefully
I wouldn't take stock valve train to 4,000rpms everyday. A 24valve valve train is much stouter than a 12valve so crank it up. :Thumbup:
You will want to keep that Smarty on the even setting running it with an Edge box and if you are cranking the Edge up about 4 or 5 yoiu will have bettter #'s on level 6 than 8 on the Smarty.
DB
Valve contact has been noted as low as 3700RPM on the 3rd Gen motors. But with a stock camshaft you may be able to run at or close to 4000RPM without damage, it's really your decision.
1 - 12 of 12 Posts
