I have a 97 466e that does not want to start. It has started intermittenly and ran for a breif period but then dies and will not start again. I pulled the codes and got 113,124,211. does the 113 code mean I am not getting power to the ecm. any help would be appreciated.
Thanks
Super Moderator
No power to the ECM = no codes retrieved.
Are any of those codes ACTIVE? Inactive codes will often cause you to waste your time.
As with any engine, you need four things to make it run:
1) RPM (fast enough to light)
2) Air
3) Fuel
4) Spark (compression in a diesel)
A problem with any of those 4 things and it won't start.
