im a cummins guy but me and my buddy has a 2006 duramax 3/4 ton 4x4 truck and we want to start puttin HP to tha ground so are there any free mod's we can start out with first ive herd of an EGR delete and stuff like that and we wats some info on a good programmer so if yall couls help us out it would be freat thx coalfed
Socal Diesel Trucks
I would look into PPE tuner for a good starter tuner . You can start with a standard with 3 tunes . Then later upgrade to hotter tunes . You need the transmission beefed up for the bigger tunes . Yes block off egr . You get the code cleared automatically with the ppe tuner . And all the other things it does . Tire size , MPH limiter , scan mode , code clearing . Pretty trouble free product . There are many other decent tuners , but this would be my choice to get easy to use power that is reliable and good tuning . I still use it after 4 years .
Later you would step up to EFI Live when you are ready to play with your own tuning . Id start with a hand held tuner . Later even with using EFI you will still use your ppe for easy code reading and clearing . Much easier than hooking up your laptop while driving .
Good Luck with the truck on whatever you choose . Many to choose from .
Johnny
CRAZY CANUCK
:stupid:rock
the lbz is a bad piece of equipment in the right hands...
Also for the transmission, i would look into Suncoast, a stage 3(up to 500hp) or stage 4(500hp and up) kit will do for a lot of power, the Stage 5 transmission is for the guys who have 800hp or more...
and a free mod is the PPE airbox mod, if you do buy a PPE tuner you will get instructions with it on how to modify the stock airbox to flow ALOT better than stock....:thumbsup
