1 - 19 of 19 Posts
does anyone on here have any experience with the dynaflex slip in mufflers? I really need to do something about the noise on this thing since I put the marine cam in, and they would be my first choice(6"). I am wondering about the sound level. dynaflex says they are comparable to stock. I want quieter but hopefully not THAT quiet. the ones I'm referring to are the kind that slip inside of a straight pipe. they are the screen design not the auger type.
i tried them on a set of 8s and couldn keep the dam things from rattlin inside the pipe.took em back out and really couldn tell a difference in noise.
Take a look at this site www.macmuffler.com
They make a small silencer called the minimac, it goes on under the truck and really takes the droan and harshness out but still sounds nice.
That's all I run on my 2ws with straights. This is all you need. They are a bit pricey but they do what they say and are built well. :rock
off topic...what did the marine cam do for HP gain?
Discussion Starter · #5 ·
Horsepower gain questions are ALWAYS on topic! that is kind of a hard question to answer. I installed that cam at the same time that I derated the ecm and removed my high flow injectors. the only true number I have is a dyno test before all this was done-740rwhp. right now I can only guess but my best estimate is about 625, that's a stock 550 ecm,stock injectors, marine cam. I'm sure the cam helps and I'm glad I installed it but going from 741 to 625 is pretty hard to take! I wouldn't want to even think about driving this without the cam. it's no wonder we all wanna turn these trucks up driving them stock SUCKS! I plan on taking care of this problem in the future but I'm waiting to at least get a few break in miles on it first. the exhaust note with the cam though is the biggest difference in sound, especially on the jakes.
I have an 18" resonator under the truck and with the 6" stacks the sound was perfect. Now with 8"s its a little louder but it still takes the rough edges off. BTW I also have the same engine setup you do....
I put in a couple on 6" straights with a 550 cat. Took a little of the edge off, but definately not a stock noise level. Seemed to help with the jake more than anything else.
Discussion Starter · #8 ·
yes I see you do have the same engine setup I do! except you're running a 550 stage 1tune. I see that you say "dyno results soon".did they come in yet?? I am probably going to go with a pdi stage 1tune also, just wondering how the whole combo is working out for you.
Discussion Starter · #9 ·
thanks for the info bud. quieting the jakes is mainly what I'm after, so that might be the ticket. I have an 18 inch resonator underneath also but I gutted the baffels a long time ago. it was fine before I installed the cam, now I wish I wouldn't have done that.
Is it still good on the jakes?
Has the EGT's dropped?
Do you notice less turbo lag because of the advance of the injector timing due to a steeper rake on the injector lobe.
And the most important . . . . . . dose it sound coooool:)
The ECM I have is a 550 heavy haul from Cat,not pdi. Maybe ya meant the turbo. I did not get it dyno'd yet but the mechanics dyno'd several setups exactly like mine and got 672. I don't know what the torque level was. Im very satisfied with this setup,mpg,egt,and drivability :)
672hp from a stock Cat 550 file with stock injectors?
Stock 550 heavy haul w/ fuel and injector trim codes. 57s are the injectors. Marine cam pdi stage 1 Turbo.
Reactions: justdoug
......but going from 741 to 625 is pretty hard to take! I wouldn't want to even think about driving this without the cam. it's no wonder we all wanna turn these trucks up driving them stock SUCKS! I plan on taking care of this problem in the future but I'm waiting to at least get a few break in miles on it first. the exhaust note with the cam though is the biggest difference in sound, especially on the jakes.
:wtf
Hard to get used to 625 again? I think that the POS 5ek I have right now is running maybe half that.:not me Atleast that is how it seems. It can drive a man to :(
100,000 with a 355 blows!choppingwood
With the fuel mileage, it should be running 700hp +:bdh
Discussion Starter · #15 ·
:wtf
Haha I hear you man! I really hate to say it it sounds like I'm crying.It does run pretty respectable, just can't excelerate uphill with 80,000 pounds with the 4 wheelers anymore
What is this "Accelerate uphill with the 4 wheelers" you speek of?
What is this "Accelerate uphill" you speak of? :roflol:
:happydance
Discussion Starter · #17 ·
something that if done properly and on a consistent basis will leave you with a permanent grin on your face!
1 - 19 of 19 Posts
