1 - 11 of 11 Posts
ODRA Outlaw Diesel Racing Association is having a Diesel only Dyno Day on Saturday, August 12th at Performance Diesel Located at 411E. Lennon Dr. Emory, TX 75440
:woot: :woot: :poke:
we pulled down on a mustang dyno...........
wait for it
325 hp/ 874 Tq
:eek:mg
and this from a basically stock 06 6.0 :poke:
ran a second truck with same engine and a few days between build dates
pulled 325 and 879
thats what we thought, but then we ran another 06 6.0 and got the same numbers and a few 7.3 that hit the sam dynoes from another place, I suspect teh tq is a bit high, i will run it through the cray computer today at work and see
my max numbers came in at 3000-3200 rpm
no pounding just smooth take off and then wot after it shifted up
i had figured doing the math to be anywhere from 270-300 on hp and 600-678 on tq, i guess 18% isnt going to work anymore ,
Is that RWHP? I would be interested in seeing it does with a tuner.
My truck Stock did. 271.1 Rwhp Torque 487.7
You got a beast of a truck there.
yep rwhp
it was very pleasing to see it lay down that well
yea that dyno has been suspect to say the least, we had a few stock cummins that dynoed at 250 is go over 300 down there. i would not hold your breath to hit those #s anywhere else.
i ran the numbers at work and the tq
either way it gave me a baseline of units...
325 units stock
so when i add a tuner it will be xxx units
only on that dyno
gunracer1 said:
only on that dyno
yep its close to where I am moving so after we do some upgrades i will re-run it
F
I would not put money on those #'s being right. That's the only dyno your gonna find 325 hp stock 6.0's
we should be finding out soon enough.
i have to drop two rear tires to use the one close to me in north bama
maybe oct.
1 - 11 of 11 Posts
