1 - 20 of 35 Posts
never dynoed an auto truck before, going friday to dyno the f250 with spartan 210 on it against some of my mustang buddies, can someone explain if the dynojet needs to be loaded a certain way or if that is only on the mustang dynos??
also how do you make a pull with the auto, shift through the gears till D and then run up the rpm then WOT??
I Eat Rice
Im a dyno virgin too. But from what Ive read here and on other forums. The dyno will have to be preloaded otherwise you wont be able to build the boost to get good numbers. I think everyone said to set the preload to about 40%. As for going through the gears. I would recommend flogging on your truck a day or two in advance of the event to tighten up the shift points and tranny. Once you are on the dyno. Bring the truck up to speed until the converter locks up. And then squeeze the throttle as hard as possible without making it down shift until you can mash it. Anything above 80mph and you should be flat on the floor. This might take a couple tries to get the pedal feel right.
Good luck and get some big numbers.:thumbsup
anyway to tell when converter locks up just by feel i guess?,,
all ive ever dynoed has been my mustangs and a few vettes but manuals are a lot easier to get correct! ive got a 600RWHP turbo stang that is fixing to be 1000RWHP :)
just wanna lay down some good numbers with the 210,, already beat up on some of my friends stangs at the track at 14.35 :)
I Eat Rice
The converter locks when you get into OD. If you use the DD watch the tranny slip channel you'll see it lock. Slip will go from 100ish to almost 0.
cool ill make sure i have it up then, so no reason to shift through gears just stick it in D an wait for lockup on DD and slowly mash it?
I Eat Rice
As far as I know.
cool thanks for the help
think i will reload the 210 v2 tune again and flog it good the next couple days!
Auto's are for pansies
I'm pretty sure you load the Mustang Dyno to some percentage, and the DynoJet is to be left alone. I'm 90% sure.
kinda what im thinking too, the mustang dynos you can def load, i think the jets are just loaded by the rollers only
Another good way to test things before going to the dyno is to drive down the highway at normal speed, make note of how fast you are going and mash the pedal to the floor. If you have enough speed, the truck will not downshift. Keep doing this reducing speed each time until the truck starts to downshift and note the speed. You want the lowest wheel speed without a downshift when you mash the pedal for direct drive. On my truck it is around 115 km/h. Take the truck up to 3200 rpm on the dyno, no more.
so you take it to like 70mph and then mash it?
Yes. If it downshifts after mashing it at 70, try a higher speed until you find the speed where it won't downshift.
Discussion Starter #13
cool deal, will roll it up till 70 and mash it, will try it tonight on way home ill hook up the dd to read the tranny slip and check it out
thanks guys
I have never dyno ether but if you take it out of OD before you start then you only have three gears.
Bill
Discussion Starter #15
need a gear that is 1:1 though so thats the gear you wanna find, im guessing its the 4th gear?
Discussion Starter #16
where is pahrump when you need him
I Eat Rice
Just leave it drive. The truck will do the rest. If your not in drive the dyno run will be out of wack. You need converter lock up to get the numbers right. Too much converter slip otherwise. That is why dyno tunes are good. They force an early lock up and the truck wont down shift no matter how fast you are with the throttle. Just stays locked up and PULLS!!!
Discussion Starter #18
cool, will let you guys know numbers when i get them
as long as this rain goes away after 15 straight days of rain in OK finally seeing the sun this afternoon, got 30% chance tomorrow and 50% chance friday
is here and there.
pretty sure the owner of the dyno will either do it all himself (David Dunbar) or will be standing right next to you telling you what to do.
Discussion Starter #20
i dont let the dyno operators pull my vehicles, they would rather i did it anyway b/c they dont want to be liable for it, however these guys havent done many trucks, we are having a mustang dyno day just to get them some business they are more of an import tuner shop and when i mean import not a frigging honda either, supras/lexus/porsche etc
making us a good deal so bunch of guys coming out, they are good with what they do though
buddy of mine made 725rwhp on a 331 with 76mm through a glide three weeks ago!
ive been to too many dyno sessions with my car watching others pull their own and too many nitrous backfires, etc to let the owner pull my car
1 - 20 of 35 Posts
