Dynomite diesel injectors.... Any good?
I'm looking at the 110hp set.
I just installed the edge comp and wasn't impressed so I'm going to put bigger injectors in then see if I like it. If I don't then I'm going to try the 110hp injectors with the ez/quad stack that I was running before.
Are the 110's ok or should I go bigger?
hey you need to talk to RED DRAGON he has the 110 hp ddp in his truck.
I've heard nothing but good on Dynomites injectors. Thats probably as big as you want to go with a stock turbo while maintaining low EGT's.
I don't have a stock turbo, I have an hx40, I need some big injectors to help the comp get this thing spooled, it wont turn 28psi with the edge stage 2's and the comp on 5x5.
but with the ez/quad stack it will pull 40psi all day, I'm trying to find a set up that will get me around 35psi at wot.
Part: #DDP 98502ISB150
Price: $799.00
since u have a bigger turbo these are the 150hp ones maileage willeither stay the same or go up by one mile to the gallon capable of 500+hp with a box and turbo this right from them i did some researching i think these are a good set up inectors for ur truck
i am glad my research was useful and if u go with those you will have to let me know how they are i am right putting all my mine into my pulling truck so i really cant afford to do anything to my street truck
